Participant manish.ranade
IDCODE reading
I am treating Xilinx FPGA (some sp3 device) as a "standard boundary scan" device.
Want to read its Device ID.  Using custom s/w over FTDI chip 2232H which acts as USB-JTAG converter.
Test#1:If I shift-in IDCODE instruction then I am able to read 32-bit Device ID correctly.
There is another way to read Device ID
Test#2: After resetting TAP, if one moves directly into SHIFT-DR state, IDCODE instruction gets loaded and one can shift-out 32-bit Device ID.   -- experts let me know if this understating correct
I am getting only 12 lsbs correct (LSB which is mandatory "1" as per JTAG standard and 11-bit manufacturer's ID) - verified against BSDL file for the device.
Test#3: Did test #2 using iMpact s/w and Xilinx platform USB cable. Used iMpact in BSCAN - debug mode.
The result is as same as #2.
So the question is, do Xilinx FPGAs behave as "standard Boundary scan devices"?
Scholar austin
Re: IDCODE reading
manish,
The devices meet the JTAG standard (verified by third party programmers).
Austin Lesea
Principal Engineer
Xilinx San Jose
Re: IDCODE reading
Hi Austin,
Below is the log from impact in batch mode.
The bits other than mandatory LSB and 11-bit manufacturer code are different in 2-methods, hence the doubt
The device uses is XC3SD1800A_FG676
Reset Tap
bsdebug -tms 1 -tdi 1 -tck 7
TMS value: 1
TDI value: 1
NO of pulses7
TDO Capture Data: 1
Elapsed time = 0 sec.
read IDCODE instruction
bsdebug -scanir 001001
TDO Capture Data: 010101
shift-in dummy 32 bits to scan-out device ID
bsdebug -scandr 0x01234567
TDO Capture Data: 00000111000010000000000100100110
There's 0 at LSB (lets ignore it for time being, rest of the 31 bits match as per device ID)
Now reading idcode without giving explicit read-IDCODE instruction
Reset Tap
bsdebug -tms 1 -tdi 1 -tck 6
TMS value: 1
TDI value: 1
NO of pulses6
TDO Capture Data: 1
Moving to SHIFT-DR
bsdebug -tms 0 -tdi 0 -tck 1
TMS value: 0
TDI value: 0
NO of pulses1
TDO Capture Data: 1
bsdebug -tms 1 -tdi 0 -tck 2
TMS value: 1
TDI value: 0
NO of pulses2
TDO Capture Data: 1
> IN Shift-DR NOW
TDO Capture Data: 11100101000001010111000010010011
mandatory LSB is "1" next 11-bit manufacturer ID also correct.  But the later bits are messed-up
