Visitor sibythachil
ILA AXI waveform window empty
Vivado Version: v2014.4.1(64-bit)
Board: ZC706 Evaluation Kit
Scenario: I had ILA1 with native signals x,y,z signals. ILA2 is added in AXI Lite configuration.
ILA1 and ILA2 signals are shown in debug_nets.ltx. In Harware Manager window I am able to trigger for ILA1 x,y,z signals
Issue:  But ILA2 AXI signals show an empty waveform window on trigger/trigger immediate.
Options tired: I removed ILA1 completely and kept only ILA2. ILA2 waveform window is still empty. Strange warning that it was not able to find objects from ILA1 which was removed ?
WARNING: Simulation object X was not found in the design.
WARNING: Simulation object Y was not found in the design.
Thanks in advance.
Visitor sibythachil
Re: ILA AXI waveform window empty
It worked when I restarted the machine :-)
Regards.
Thachil
Visitor sibythachil
Repetitive trigger works for ILA2 alone design. The waveform window gets refreshed. But it is empty!
Also, I will NOT be able to migrate to newer version of Vivado.
When you removed ILA1 from your design have you re-run the complete flow?
If yes, then check if you are pointing to coorect BIT and LTX files.
Secondly when you are trying to capture signals for AXI is your trigger condition met properly? Is clock for ILA is free running?
Yash
Visitor sibythachil
hi Yash,
I have given a complete re-run. Yes trigger condition is met. I close the waveform window and when the trigger condition is met the window opens again but it is empty. On immediate trigger also waveform windows is empty.
Timing is met. I have connected axi lite clock to the ILA.
Visitor sibythachil
Regards.
Thachil
Thanks for updates,
Please close this thread by marking answer Accept as Solution
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
