AleRoss
ILA error during synthesis
A very simple board design does not finish synthesis due to ILA not generating correctly.
Board designBoard design
The hierarchy in the board design containing the ILA is the one on the left
HierHier
The log for the generation of the ILA is the following:
*** Running vivado
    with args -log design_1_ila_0_1.vds -m64 -product Vivado -mode batch -messageDb vivado.pb -notrace -source design_1_ila_0_1.tcl
****** Vivado v2020.1 (64-bit)
  **** SW Build 2902540 on Wed May 27 19:54:35 MDT 2020
  **** IP Build 2902112 on Wed May 27 22:43:36 MDT 2020
    ** Copyright 1986-2020 Xilinx, Inc. All Rights Reserved.
source design_1_ila_0_1.tcl -notrace
WARNING: [Vivado 12-818] No files matched '/home/alessandro/VivadoWorkspace/project_3/project_3.srcs/sources_1/bd/design_1/ip/design_1_ila_0_1/ila_v6_2/constraints/ila_impl.xdc'
ERROR: [Common 17-55] 'set_property' expects at least one object.
Resolution: If [get_<value>] was used to populate the object, check to make sure this command returns at least one valid object.
INFO: [Common 17-206] Exiting Vivado at Wed Sep 30 13:58:39 2020...
The file ila_impl.xdc does exist where vivado searches for it and it's the following:
## Match Unit Configuration to Match Output false path
set_false_path -from [get_pins -filter {REF_PIN_NAME=~CLK*} -of_objects [get_cells -hierarchical -filter {NAME =~ "*allx_typeA_match_detection.ltlib_v1_0_0_allx_typeA_inst/DUT/I_WHOLE_SLICE.G_SLICE_IDX[*].U_ALL_SRL_SLICE/u_srl*/S*"}]] -to [get_pins -filter {REF_PIN_NAME=~D*} -of_objects [get_cells -hierarchical -filter {NAME =~ "*allx_typeA_match_detection.ltlib_v1_0_0_allx_typeA_inst/DUT/I_WHOLE_SLICE.G_SLICE_IDX[*].U_ALL_SRL_SLICE/I_IS_TERMINATION_SLICE_W_OUTPUT_REG.DOUT_O_reg*"}]]
## ILA Sample Counter Match Condition out False Paths
set_false_path -from [get_pins -filter {REF_PIN_NAME=~CLK*} -of_objects [get_cells -hierarchical -filter { NAME =~  "*ila_core_inst/u_ila_cap_ctrl/u_cap_addrgen/u_cap_sample_counter/u_scnt_cmp/allx_typeA_match_detection.ltlib_v1_0_0_allx_typeA_inst/DUT/I_WHOLE_SLICE.G_SLICE_IDX[*].U_ALL_SRL_SLICE/u_srl*/S*"}]] -to [get_cells -hierarchical -filter { NAME =~  "*ila_core_inst/u_ila_cap_ctrl/u_cap_addrgen/u_cap_sample_counter/u_scnt_cmp_q*" && IS_SEQUENTIAL } ]
## ILA Window Counter Match Condition out False Paths
set_false_path -from [get_pins -filter {REF_PIN_NAME=~CLK*} -of_objects [get_cells -hierarchical -filter { NAME =~  "*ila_core_inst/u_ila_cap_ctrl/u_cap_addrgen/u_cap_window_counter/u_wcnt_lcmp/allx_typeA_match_detection.ltlib_v1_0_0_allx_typeA_inst/DUT/I_WHOLE_SLICE.G_SLICE_IDX[*].U_ALL_SRL_SLICE/u_srl*/S*"}]] -to [get_cells -hierarchical -filter { NAME =~  "*ila_core_inst/u_ila_cap_ctrl/u_cap_addrgen/u_cap_window_counter/u_wcnt_lcmp_q*" && IS_SEQUENTIAL } ]
set_false_path -from [get_pins -filter {REF_PIN_NAME=~CLK*} -of_objects [get_cells -hierarchical -filter { NAME =~  "*ila_core_inst/u_ila_cap_ctrl/u_cap_addrgen/u_cap_window_counter/u_wcnt_hcmp/allx_typeA_match_detection.ltlib_v1_0_0_allx_typeA_inst/DUT/I_WHOLE_SLICE.G_SLICE_IDX[*].U_ALL_SRL_SLICE/u_srl*/S*"}]] -to [get_cells -hierarchical -filter { NAME =~  "*ila_core_inst/u_ila_cap_ctrl/u_cap_addrgen/u_cap_window_counter/u_wcnt_hcmp_q*" && IS_SEQUENTIAL } ]
create_waiver -internal -scope -type CDC -id CDC-1 -from [get_pins -filter {REF_PIN_NAME=~CLK} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/U_CDONE/I_YESLUT6.U_SRL32_*"}]]  -to [get_pins -filter {REF_PIN_NAME=~D} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/U_CDONE/I_YESLUT6.I_YES_OREG.O_reg_reg*"}]]  -tags "1037291" -user "xsdbm" -description {CDC is handled through handshake process}
create_waiver -internal -scope -type CDC -id CDC-1 -from [get_pins -filter {REF_PIN_NAME=~CLK} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/U_NS1/I_YESLUT6.U_SRL32_*"}]]  -to [get_pins -filter {REF_PIN_NAME=~D} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/U_NS1/I_YESLUT6.I_YES_OREG.O_reg_reg*"}]]  -tags "1037291" -user "xsdbm" -description {CDC is handled through handshake process}
create_waiver -internal -scope -type CDC -id CDC-1 -from [get_pins -filter {REF_PIN_NAME=~CLK} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/U_NS0/I_YESLUT6.U_SRL32_*"}]]  -to [get_pins -filter {REF_PIN_NAME=~D} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/U_NS0/I_YESLUT6.I_YES_OREG.O_reg_reg*"}]]  -tags "1037291" -user "xsdbm" -description {CDC is handled through handshake process}
create_waiver -internal -scope -type CDC -id CDC-1 -from [get_pins -filter {REF_PIN_NAME=~CLK} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/u_cap_addrgen/u_cap_window_counter/U_WCE/I_YESLUT6.U_SRLC16E*"}]]  -to [get_pins -filter {REF_PIN_NAME=~CE} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/u_cap_addrgen/u_cap_window_counter/iwcnt_reg[*]*"}]] -tags "1037291" -user "xsdbm" -description {CDC is handled through handshake process}
create_waiver -internal -scope -type CDC -id CDC-1 -from [get_pins -filter {REF_PIN_NAME=~CLK} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/u_cap_addrgen/u_cap_sample_counter/U_SCE/I_YESLUT6.U_SRLC16E*"}]]  -to [get_pins -filter {REF_PIN_NAME=~CE} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/u_cap_addrgen/u_cap_sample_counter/iscnt_reg[*]*"}]] -tags "1037291" -user "xsdbm" -description {CDC is handled through handshake process}
create_waiver -internal -scope -type CDC -id CDC-1 -from [get_pins -filter {REF_PIN_NAME=~CLK} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/u_cap_addrgen/u_cap_sample_counter/U_SCMPCE/I_YESLUT6.U_SRL32*"}]]  -to [get_pins -filter {REF_PIN_NAME=~CE} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/u_cap_addrgen/u_cap_sample_counter/u_scnt_cmp_q*"}]]  -tags "1037291" -user "xsdbm" -description {CDC is handled through handshake process}
create_waiver -internal -scope -type CDC -id CDC-1 -from [get_pins -filter {REF_PIN_NAME=~CLK} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/u_cap_addrgen/u_cap_window_counter/U_WHCMPCE/I_YESLUT6.U_SRL32*"}]]  -to [get_pins -filter {REF_PIN_NAME=~CE} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/u_cap_addrgen/u_cap_window_counter/u_wcnt_hcmp_q*"}]]  -tags "1037291" -user "xsdbm" -description {CDC is handled through handshake process}
create_waiver -internal -scope -type CDC -id CDC-1 -from [get_pins -filter {REF_PIN_NAME=~CLK} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/u_cap_addrgen/u_cap_window_counter/U_WLCMPCE/I_YESLUT6.U_SRL32*"}]]  -to [get_pins -filter {REF_PIN_NAME=~CE} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/u_cap_addrgen/u_cap_window_counter/u_wcnt_lcmp_q*"}]]  -tags "1037291" -user "xsdbm" -description {CDC is handled through handshake process}
create_waiver -internal -scope -type CDC -id CDC-10 -from [get_pins -filter {REF_PIN_NAME=~CLK} -of_objects [get_cells -hierarchical -filter {NAME =~ "*allx_typeA_match_detection.ltlib_v1_0_0_allx_typeA_inst/DUT/I_WHOLE_SLICE.G_SLICE_IDX[*].U_ALL_SRL_SLICE/u_srl*/S*"}]]  -to [get_pins -filter {REF_PIN_NAME=~D} -of_objects [get_cells -hierarchical -filter {NAME =~ "*allx_typeA_match_detection.ltlib_v1_0_0_allx_typeA_inst/DUT/I_WHOLE_SLICE.G_SLICE_IDX[*].U_ALL_SRL_SLICE/I_IS_TERMINATION_SLICE_W_OUTPUT_REG.DOUT_O_reg*"}]]  -tags "1037291" -user "xsdbm" -description {CDC is handled through handshake process}
#create_waiver -internal -scope -type CDC -id CDC-10 -from [get_pins -filter {REF_PIN_NAME=~CLK} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_trig/N_DDR_TC.N_DDR_TC_INST[*].U_TC/allx_typeA_match_detection.ltlib_v1_0_0_allx_typeA_inst/DUT/I_WHOLE_SLICE.G_SLICE_IDX[*].U_ALL_SRL_SLICE/u_srlD/S1*"}]]  -to [get_pins -filter {REF_PIN_NAME=~D} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_trig/N_DDR_TC.N_DDR_TC_INST[*].U_TC/allx_typeA_match_detection.ltlib_v1_0_0_allx_typeA_inst/DUT/I_WHOLE_SLICE.G_SLICE_IDX[*].U_ALL_SRL_SLICE/I_IS_TERMINATION_SLICE_W_OUTPUT_REG.DOUT_O_reg*"}]]  -tags "1037291" -user "xsdbm" -description {CDC is handled through handshake process}
create_waiver -internal -scope -type CDC -id CDC-10 -from [get_pins -filter {REF_PIN_NAME=~CLK} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/u_cap_addrgen/u_cap_sample_counter/U_SCE/I_YESLUT6.U_SRLC16E*"}]]  -to [get_pins -filter {REF_PIN_NAME=~D} -of_objects [get_cells -hierarchical -filter {NAME =~ "*u_ila_cap_ctrl/u_cap_addrgen/icap_wr_en_reg*"}]]  -tags "1037291" -user "xsdbm" -description {CDC is handled through handshake process}
My same error is reported in at least three other posts without any response:
https://forums.xilinx.com/t5/Processor-System-Design-and-AXI/Vivado-2018-3-Failed-to-synthesized-ILA/td-p/941129
https://forums.xilinx.com/t5/Synthesis/ILA-IP-synth-error/td-p/1107262
I'm using Ubuntu 20.04.1 LTS and Vivado 2020.1 (SW/HW build can be seen in the log for the IP generation).
The same error is given in this occasions:
  • using System ILA
  • marking the nets as DEBUG and letting Vivado generate the ILA
  • resetting outputs for the block design
The error dissapers if the ILA is in AXI mode (not NATIVE or MIXED)
How should i proceed?
Not having ILA makes everything quite difficult.
Best regards,
Alessandro
