junnit
ILA triggered but on waveform uploaded
Hi xilinx employees,
I am debugging my circuits with the ILA tool, I have set the trigger condition, when I insert a reset to my board, the ILA become Post-triggerred from the waiting for trigger, but there is no waveform uploaded.
it drives me crazy......
anunesgu
Hi @junnit ,
So we can narrow down the problem, could you please inform the follow itens:
  • What is the Vivado version that you are using? Is this issue specific for that Vivado installation or does it also happen with newer/older versions?
  • What is the OS that you are using? If Linux, what distro?
  • Could you try to reduce the JTAG clock speed (when you connect to the board) and try again? It needs to be at least 2.5x slower than the ILA clock.
  • Does this issue happens pnly with a specific design or you see the issue in any design with an ILA?
Andre Guerrero
Product Applications Engineer
