Observer navya_k
Hi, i am new to fpga, in ILA how can we makw the ILA work only when the given trigger signal is 1,only at that time the outputs have to be captured and all remaining times it doesn't capture the output?
thanks in advance,
navya
When you add ila to your project, you can select the comment signal as the data and trigger. Then, after create bitstream and program it, you open the desired ila. Then in the trigger settup you add your signal and set it when see the '1'.  Additionally you can specify the location of the trigger in the position window.
Observer navya_k
Thank you for the reply.
Navya
