tom.hilgerdenaar
ISE 14.7 Impact failing to load libPort_ExecLoader.dll on Windows 10 (KB4338826 and KB4338832)
The Impact tool has the following issue in Windows 10 (at one of my customers):
C:\usr\CurrentBitFile>C:\Xilinx\14.7\LabTools\LabTools\bin\nt64\impact.exe -batch magnum_acp.cmd
Failed to load library libPort_ExecLoader.dll because of Execution of the dynamic link library (DLL) initialization routine failed
Is there any known fix?
Thank you,
Tom Hilgerdenaar
Avnet - Xilinx FAE
peadard
Hi @tom.hilgerdenaar, as you already know, ISE 14.7 is not officially supported on Windows10, unless the customer is targeting Spartan-6
Does the information provided in the following topics help?
https://forums.xilinx.com/t5/Configuration/Impact-libPort-ExecLoader-dll-issue/m-p/873096
https://forums.xilinx.com/t5/Installation-and-Licensing/Xlinx-giving-dll-error-after-windows-update/m-p/873947
