quincyq2003
ISE simulation library
Hello
I want to know, where is the ISE simulation library path.
vuppala
Hi @quincyq2003
ISE Simulation libraries are located in the ISE installed directory.
Verilog Simulation libraries:<installed_dir>\Xilinx\14.7\ISE_DS\ISE\verilog\src
VHDL Simulation libraries:<installed_dir>\Xilinx\14.7\ISE_DS\ISE\vhdl\src
Vinay
vuppala
Hi @quincyq2003
Vinay
