bcarltontrex
In VIO display in Hardware Manager, can't drag and drop to reorder signals (Vivado 2016.4, Windows 64-bit)
This is in the hw_vios tab. You can in the ILA window. It appears they are always sorted by whichever column is selected (e.g. Name, Value).
bcarltontrex
I think I have solved this. You have to force off sorting. For example if sorted by name, ascending. Click on Name to sort descending. Click again and it isn't sorted. Then I can move around nets.
bcarltontrex
vijayak
Hi @bcarltontrex
Thanks for posting the solution. This will help the other users facing similar issues.
Thanks,Vijay
prathikm
Hi @bcarltontrex,
Please mark your post as an answer "Accept as solution" since it helped resolve your query and would benefit other users, as vijayak pointed out.
Prathik
