In vivado Hardware manager, how to load wave configuration?
 I'm using vivado2014.4 and I'm debugging a project in zc706.
 Every time I open the hareware manager ant connect the board and sample, the wave window resets the wave configuration.
 How can I load the wave configuration I saved last time in the Hardware Manager?
Regards.
Re: In vivado Hardware manager, how to load wave configuration?
@marsmoon
I think you can load .wcfg and wdb files, please go through "ILA Data and Waveform Relationship" section from UG908 and see if it helps
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug908-vivado-programming-debugging.pdf
If in case you want to open existing ila file please go through "Restoring Captured ILA Data from a File" from the same UG
Hope this helps
-Vanitha
@marsmoon
Hope this helps
-Vanitha
you can save the hardware manager project and reopen when you want to debug design .
Thanks and Regards
Balkrishan
