evgenis1
Advisor
Advisor
Interpreting GTY Ibert eye scan results
I'm having a problem interpreting GTY Ibert eye scan results. Attached are three scans:
  1. Good eye scan: PRBS31, DFE=on   (eye1.jpg)
        Looks as expected.
  2. PRBS31, DFE=off (eye4.jpg)
      I cannot explain why the eye gets out of vertical borders.
  3. Slow clock data pattern, DFE=on (eye2_slow_clock.jpg)
     On the scope I see a low-jitter shape resembling sine wave. But Ibert eye scan produce this strange triangle shape.
Evgeni
dwisehart
Top looks fine. Middle one would probably drop back if you pull back the gain setting. Bottom one looks like it has DC offset.
bfung
@evgenis1 Did you ever find a solution for the second eye scan (with the eye extending past the vertical axis)? I'm currently running into the same problem!
evgenis1
Advisor
Advisor
@bfung
No, I have not.
bfung
