Is there a way to detect a signal combination in chipscope
Hello every one,
as the title suggest, Is there a way to detect a signal combination in chipscope
I know we can do some similar thing with trigger conditions, but I dont want them to use aas triggers, but I have few glitches in my design that I found accidently, hence I want to know if  there is any way I can find the combination. The process halts there etc.
Of it there is any other trchnique that experienced users use then please share with me.  I will surel;y appreciate it.
Thanks in advance,
sraza
yes,
we can havve multiple triggers(multiple instances of same trigger port) and then we can use the AND/OR options in the chipscope analyzer to select the combination
yes,
