l889
Labview-VI with chipscope integration????
Hi!
Is there any way to integrate chipscope into an labview-vi to automate testing of a FPGA design?
Thank you!
John
l889
no answers???? OK, then I'll present my solution here: There are example TCL-Scripts located in the Chipscope-Folder. Using them it's possible to read and write to any VIO component in a DOS-prompt. To access from LabView or Matlab you need only a litte interface code to exchange the command-line data with the TCL-script..... John
l889
ashishnarnoli
I need to control chipscope ila cores using LabView. Please help.
Ashish
teidatm
I have the same interest, control ILA from Labview.
Thanks for your support!
