daldoul
Link for ChipScope tutorial is not working !!
I try to download the "" Design Files ""  for ChipSope Pro Tutorials (- Using Xilinx ChipScope Pro ILA Core with Project Navigator to Debug FPGA Applications) from this link http://www.xilinx.com/training/fpga-tutorials.htm  ,  But the link is not working and it is redirected to another.
hj
Check this link.
http://xgoogle.xilinx.com/search?getfields=*&numgm=5&filter=0&proxystylesheet=support&client=support&site=Answers_Docs_Forums&q=chipscope+labs&getfields=*&ie=UTF-8&num=1000&oe=UTF-8&output=xml_no_dtd&requiredfields=-Archived%3Atrue&show_dynamic_navig...=
There you can find this
From there click on the zip file & download the design files.
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
hj
Hi ,
check out this link
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_3/ug750.pdf
daldoul
Thanks for your response,
In fact,  the link that contains the  design files (ug750) still not working.
  Design files:
• debounce.vhdl - Debounce circuit
• fsm.vhdl - Control state machine
• sinegen_demo - Wrapper for Sine wave generators
• sinewave_demo - Top-level wrapper design
• sine_high.xco, sine_mid.xco, sine_low.xco - Xilinx Core Generator files
• sinegen_demo_sp601.ucf - UCF constraint file
vemulad
I tried accessing them at website (link) and it errors out as below
We cannot fulfill your request due to technical difficulties. Please try again later.
Please do NOT click the back button. Please try again later, and email webmaster@xilinx.com if you receive this error repeatedly.
It looks like there is some problem here. I reported this to the website team by emailing to above email id.
Cheers,
Deepika.
Deepika.
pratham
HI,
Why don't you take a look into this
http://www.xilinx.com/csi/training/chipscope-pro-software-overview.htm.
Download Lab files and follow the instructions.
Pratham
-Pratham
hj
Check this link.
lavigne
OK, glad I found this forum post and solution.
I submitted a support ticket prior to finding this post.
Why has this not been addressed for 40 days?
