Missing XGD file
I have a design targetting the xc7k160 FPGA using Vivado 2015.3 on Windows 7 64 bit.  The implementation flow succeeds.  When I go to open the timing report or open the implemented design, Vivado crashes.  I get an error message: "Xgd file 'xc7k160t.xgd' is missing.  Exiting Vivado..."
The file is present in the ...\data\parts\xilinx\kintex7\devint\kintex7\xc7k160t folder.
This problem only started appearing recently.  Any ideas on how to fix this?
I was able to fix it by deleting the .runs, .cache, .ip_user_files, .hw folders, and rebuilding the project file.  Just deleting the runs and other folders was not enough.
@barry0727 Did you delete any of the files from installation? please copy this file to the location and give a try .
if this doesnt help then please reinstall the tool.
-Pratham
I didn't delete any files.  Where should I put those files?  I don't see any similar files with _detail or _floorplan suffixes in my installation.
@barry0727 Paste it here
C:\Xilinx\Vivado\2015.3\data\parts\xilinx\kintex7\devint\kintex7\xc7k160t
-Pratham
I tried pasting then files as you suggested.  That did not work - I got the same exception.  I then tried uninstalling (checking to see that the Vivado files were deleted), then reinstalling.  I still got the same missing xgd file exception.
The problem is design dependent.  I have a similar branch of the design, also targeting the xc7k160t that does not crash when the implementation is loaded.  I haven't diff'ed the project files yet, but I intend to check to see whether something jumps out.
@barry0727 Glad to know. Please close this thread.
-Pratham
