Multiple ILAs on same clock
I have a large design that all runs on the same clock. i'd like to probe sections of the chip on separate ILAs otherwise it takes 30 to 60 seconds to upload the scope data, most of which I'm not interested in at the time. Near I can tell the only way to gen a new ILA is with a new clock. Suggestions???
Tags (3)
Re: Multiple ILAs on same clock
That computer died and my new laptop was much quicker. Turned out to be slow because of the USB 2.0 link. The laptop was 3.0.
Give a single clock for all the trigger signals. this will creae only a single ila core for all the signals and hence show the waveform for all signals. The trigger clock can be different from the actual clock at which that module is running.
Thanks and Regards
Balkrishan
Hi @frankz,
You can go for a different ILA clock. But prior to that try changing JTAG clock frequency and see if it helps.
Arpan
I changed from 15MHz to 30MHz, which is the fastest available that I've been able to determine. It's still taking a minute 55 seconds to upload.
Hi @frankz,
What is the datadepth? Can you try with multiple windows?
Arpan
Have you tried instantiation flow to generate different ILA's instead of post synthesis insertion flow to add the signals to ILA?
Satish
Thought about it, just a bit more rigid.
Is there a way in the GUI or is this my only shot?
