Observer bharathmanogna
Multiplier Power using XPA
Hi all,
I am using XPA to compare power consumptions of two different algorithms.
both of them are almost similar and use a multiplier , but one has a result very much different from other , which is not expected,so i want to know the method XPA uses to compute Multiplier power consumption.
Please suggest where i can find a detailed description on multiplier power consumption.
Re: Multiplier Power using XPA
There could be some design differences in both cases. Also try in same versions of tools.
Hi  Kodali,
Thank you for your response,
Actually the design is slightly different as shown below,
Code1
if(STARTOP) begin
        if(DOUT>TRESH) begin
            SUMY <= SUMY+DOUT*i;
            SUMX <= SUMX+DOUT*j;
            SUMI <= SUMI+DOUT;
        end
    end
Code2
if(STARTOP) begin
            SUMY <= SUMY+(DOUT-TRESH)*i;
            SUMX <= SUMX+(DOUT-TRESH)*j;
            SUMI <= SUMI+(DOUT-TRESH);
        end
    end
Code 1 has lesser power consmpution than Code2 which is against expectation the only difference between them is that one operand is subtrated by a default value before multiplication.
I cannot see why there must be an increase because of it, can  you explanations this.
Bharath
