Voyager
Voyager
One more issue with ILA
Does Ultrascale boards require a particular attention on using ILA.
I'm used to use ILA with Zynq-7000 board (ZC706), but have met problem with KCU105 board (Kintex Ultrascale)
It merely doesn't work: I don't see wave and trigger doesn't run (at least I don't see any "animation" on Core Status "radiobuttons").
Any suggestions ?
Voyager
Voyager
Re: One more issue with ILA
Moreover I don't see any modification in .xdc file, that affirme presence of debug staff ... no any recordings related to ILA.
And yet the probes are there.
Strange
Hi @pavel_47,
What is the JTAG baud rate that you are using? And what is the ILA clock frequency?
Could you try to lower the JTAG baud rate when you first connect to the board (reduce it to at least 2 times lower than the ILA clock frequency) and test it again.
Andre Guerrero
Product Applications Engineer
Voyager
Voyager
The problem was resolved by removing all the debugging staff and recreating it from the scratch.
