nemesisyklee
[Open Hardware Manager problem] with RHEL6.7 and Vivado 2018.2
When I open target in RHEL6.7 and Vivado 2018.2, there is no 'Hardware Target' and 'Hardware Devices' at all.
But I can find the usb connection with 'lsusb' which is linux probing cmd for usb devs' finding.
1. I used 'Open Hardware Manager'->Open Target'->'Open new target'.
   Is there any other method?
2. When I use the same version of vivado in other win10 machine, it works.
   Can I run the some specific 'exe file' just for fuzing in windows?
Thank you in advance.
thakurr
Hi @nemesisyklee
Which JTAG/USB cable you are using? Make sure it is a compatible one with Xilinx hw_server as mentioned in the link below, page 25:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug908-vivado-programming-debugging.pdf
In Linux try launching the hardware manager and connecting to hardware device by issuing the below commands:
For instance, to connect to the digilent_plugin target (serial number 210203339395A) that is managed by the hw_server running on localhost 3121, use the following Tcl commands:
connect_hw_server -url localhost:3121
current_hw_target [get_hw_targets */xilinx_tcf/Digilent/210203339395A]
set_property PARAM.FREQUENCY 15000000 [get_hw_targets \ */xilinx_tcf/Digilent/210203339395A]
open_hw_target
You can also directory launch hw_server from Vivado installation directory by running below command in the Vivado tcl shell:
C:\Xilinx\Vivado\\bin\hw_server.bat
Rohit
nemesisyklee
open_hw_target
From above, how can I find proper argument for '*/xilinx_tcf/Digilent/210203339395A'.
When I type lsusb in RHEL 6.7, it says 'Furture Technology Devices International, Ltd FT232H Single HS USB-UART/FIFO IC'.
