robert_ko
Plan Ahead IBIS export
I'm trying to export IBIS for Virtex-5 out of plan ahead with just pin assigment.   The plan ahead documentation mentions this feature avail for Virtex-7.
I don't see the option avail under File->Export.  Do I need to synthesize a partial design to get that info or is it even avail for Virtex-5?
htsvn
hi,
virtex5.ibs does not seem to exist under the location documented in this AR https://www.xilinx.com/support/answers/41685.html
you can navigate to the following location in the installation directory, PlanAhead\data\parts\xilinx\virtex5 to confirm the same.
--hs
gnarahar
@robert_ko I think the write_ibis is only from 7- series and above.
For Virtex-5, you will need to use the IBIS Writer in ISE
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
vuppala
Hello @robert_ko
Download Virtex-5 IBIS models from here.
Vinay
robert_ko
I had previously download that IBIS and forwarded to board developer but they complained the IO to IO skew was not there.
I relooked and could not even find package for XQR5VFX130 (CF1752).  Is that release imcomplete?
gnarahar
Please use IBIS Writer i.e. create custom IBIS Model from ISE for the part you are using and you should get the IBIS model that includes the package details.
- Giri
robert_ko
Can you tell what steps to take in ISE 13.2?   It looks like it lauches PlanAhead.   I'd like to go from IO csv to get package skew.
gnarahar
Follow the regular flow of Implementing the design in ISE. Once implemented, Expand the Place & Route tree to see the "Generate IBIS Model" option
With Generate IBIS Model selected, click on Process -> process properties to set the properties for the IBIS model
The generated IBIS model should have the details you looking for
- Giri
robert_ko
if I have plan ahead ucf and top level verilog (i just have wrapper only), what CLI commands to I run to get NGC file that ibiswriter needs?   Our current flow uses precision so I'd like to try to script it
robert_ko
I followed the instruction using netlist shell but IBISWRITER complains xqr5vfx130 (Rad hard Virtex-5) not supported?
Started : "Generate IBIS Model".
Running ibiswriter...
Command Line: ibiswriter -intstyle ise -truncate 20 fec1_top.ncd fec1_top.ibs
Loading device for application Rf_Device from file 'qr5vfx130.nph' in
environment /apps/xilinx/13.2/ISE_DS_v12/ISE.v12_overlay/.
"fec1_top" is an NCD, version 3.2, device xqr5vfx130, package cf1752, speed
-1
ERROR:PostProcessors:26 - IBISWriter: qrvirtex5 is an unsupported architecture.
Use ibiswriter -h to list supported architectures.
Process "Generate IBIS Model" failed
jenglee
Did anyone have better luck?  I have encountered the same issue with ibiswriter.  It looks like the overlay package never provide an updated binary to support qrvirtex5 architecture.  I can only think of an alternative to cut/paste the exported pin info on a project compiled using commercial part into the supplied .ibs.
