03-15-2013 07:42 PM
Planahead gui simply does not want to start....TCL mode runs until start_gui command is given where it fails as well.
The log file (debug with pid no) is shown below
Please help!!!
# PlanAhead v14.4 (64-bit)
# Build 222254 by xbuild on Tue Dec 18 05:17:28 MST 2012
# Current time: 16/3/13 8:06:32 AM
# Process ID: 5860
# Platform: Unix
# This file is an indication that an internal application error occurred.
# This information is useful for debugging. Please open a case with Xilinx
# Technical Support with this file and a testcase attached.
16/3/13 8:06:32 AM
java.lang.NegativeArraySizeException
at ui.data.g.e.c.a(SourceFile:422)
at ui.data.g.e.c.c(SourceFile:466)
at ui.views.k.e.d.eHn(SourceFile:1440)
at ui.PlanAhead.aJw(SourceFile:881)
at ui.PlanAhead.<init>(SourceFile:241)
at ui.PlanAhead.u(SourceFile:666)
at ui.PlanAhead.jswMain(SourceFile:713)
03-16-2013 09:15 AM
Anyone??
I am waiting here..
03-16-2013 10:20 AM
As was mentioned in this thread:
you will have the best chance for a reponse by posting the in correct forum. PlanAhead topics are discussed in the Design Planning area. If you do decide to repost don't forget to mention that OS that you are using.
