swapnamala@gmail.com
Project creation in plan ahead with edk(system.ngc)
hi i am trying to create project in planahead and i wanted to add edk(xmp)to the project. i generated netlist in edk and added system.ngc to planahead project.i am having DDR3 controller in EDK. i am getting some errors in the transulate phase(but in ise its able to run the implementation and able to test the bit file) can u please tell me did i miss any thing in the procedure Please find the below errors which i am getting in transulate phase [NgdBuild 947] bidirect pad net 'ddr_memory_dqs_n_4_OBUF' is driving non-input buffer(s): pin I on block ddr_memory_dqs_n_4_OBUF with type OBUF Like above for whole bus errors are coming
thanks in advance
vishalm
Hello Swapna,
The error itself says the root cause.
Please go through this article, this may help you understand why it is happening.
http://www.xilinx.com/support/answers/32847.htm
Vishal
thanks for ur reply.
1.i am able to generate the bit file in ise..getting this error in Plan ahead tool.in ise i mapped module serch path to EDK implementation folder.in Plan ahead i didnt find that option(module search path).
so in plan ahead under more options tab i gave -sd path(edk implementation)
but still getting the same error
thanks
