Participant geschema1
Query paths by number of stages in Planahead
In Planahead, post-synthesis, is there a way to list the timing paths that have the highest number of logic stages? The report_timing command looks for paths with the lowest slack, which is not exactly what I want.
Re: Query paths by number of stages in Planahead
The following example returns timing paths where the logic levels are greater than the specified number of logic levels:
get_timing_paths -max_paths 1000 -filter {LOGIC_LEVELS > 1}
See if this helps.
Deepika.
Deepika.
Hello Deepika,
thanks, but this does not seem to work in PlanAhead 14.6:
invalid command name "get_timing_paths"
