henkpeters
Re: iMPACT Crashes Consistently When Loading
This are very annoying crashes. When will it be solved?
hj
Check the following threads
http://forums.xilinx.com/t5/Installation-and-Licensing/iMPACT-Crashes-Consistently-When-Loading/m-p/300561
http://www.xilinx.com/support/answers/58345.htm
http://www.xilinx.com/support/answers/47890.htm
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
eteam00
Professor
Professor
This thread might also be useful.
-- Bob Elkind
SIGNATURE:
Summary:
venkata
If you are trying to load IMPACT project file from ISE tool, then please use stand alone IMPACT tool with the project file.
debrajr
@henkpeters Is the issue solved for you? If yes, feel free to mark the post which helped you the most as an Accepted Solution. It is a good forums practice.
Debraj
