bcarltontrex
Search or filter Vivado ILA (2016.4)
When I have a many signals in the ILA, it can be hard to find the ones I want in the Waveform view. Is there a way to search for a signal name? Or filter?
balkris
You can try enabling keep hierarchy option in synthesis . It will make you easy to search signals . Check these documents as well
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug936-vivado-tutorial-programming-debugging.pdf
https://www.youtube.com/watch?v=i8axs4hw2f4
Thanks and Regards
Balkrishan
bcarltontrex
@balkrisThat helps for putting them in the Vivado ILA. But when I have 100+ signals, finding the in the Waveform view can be less easy. Any ideas for that?
