Participant rs2015
Serial IO Analyzer Sweep Parameter entry problem
I am using the Vivado 2015.4 Serial IO Analyzer.
I would like to perform a sweep to vary the RXCDR_CFG parameter, which is an 18 digit hex number (72 bits).
However, I get the following error:
But this is the default value that the tool shows:
Re: Serial IO Analyzer Sweep Parameter entry problem
What is the reason for this test? can you get the required setting for RXCDR_CFG from GT wizard?
Participant rs2015
We're having trouble with PHY errors on our SATA port.  I'm investigation the configuration's effect.
I found a work-around:
1. create a sweep with one parameter, such as RXTERM
2. right-click on sweep and select properties
3. Under the PROPERTIES tab, select ITERATION_SETTINGS and enter the sweep parameters, e.g.
{DRP.RXCDR_CFG  0388008BFF40100008} {DRP.RXCDR_CFG  03800023FF40200020} {DRP.RXCDR_CFG  03800023FF10400008}
