jprice
Set Up Debug - Processing Nets Very Slow
I've got a design where I am trying to use the GUI to setup a debug ILA core. I've got about 5k signals marked for debug. When using the Set Up Debug GUI in the past I've had no problem with tens of thousands of nets. For some reason in this design, it brings up a Progress bar for filtering nets and tracing clock domains which takes a good 30 minutes, which is absurdly slower than I've seen it in the past. Does anyone know of anything I can look into to trouble shoot this? For reference this is targetting a KCU116 eval board and I am using Vivado 2019.2. I've tried in Vivado 2020.1 and seen the same issue. I cannot share the design, but let me know what other information would be useful.
Thanks!
