Setting up an equation in chipscope
Is it possible to set up the following expression in Chipscope?
!(!M1 && !M2 && !M3 && !M4) && M5
Re: Setting up an equation in chipscope
Chipscope allows 16 match units.The trigger condition sequencer can be either a Boolean equation, or an optional trigger sequencer that is controlled by the Max Sequence Levels pull-down, stored as max_sequence_levels in the XCO parameter file.The Max Sequence Levels sets the maximum levels of Match Units that can be placed in sequence by ChipScope Analyzer to activate the trigger condition. I think you can. Are you seeing any issue here?
You can also see the datasheet for more information.
http://www.xilinx.com/support/documentation/ip_documentation/chipscope_ila/v1_04_a/chipscope_ila.pdf
Sikta
Community Manager
Community Manager
I don't think this is possible. Chipscope analyzer allows us to negate individual match unit in the equation or negate the whole equation.
Here you are trying to do both. I don't think this is possible.
I'm not 100% sure as I tried it long time back. I can check this and update the thread later.
Krishna
Thanks. Please update us when you can. I have traced my problem back a different way so I don't need this capability at the moment, but I'd like to know if it's possible. Thanks again to all.
Scholar dwisehart
What about doing a boolean equivalent?  ! ( a && b ) == (  ! a ) || ( ! b )  and ! ( a || b ) == ( ! a ) && ( ! b )
A:  !(!M1 && !M2 && !M3 && !M4) && M5
Equals:
B:  (  M1 || M2 || M3 || M4 ) && M5
Test it out:
M1  M2  M3  M4  M5    A  B
 1   0   0   0   0    0  0
 1   0   0   0   1    1  1
 0   0   0   0   1    0  0
 1   1   1   1   1    1  1
 0   1   1   1   0    0  0
And so on...
Daniel
