Visitor yulek
Signals in Chipscope.
I generated ICON and ILA using coregen and added them to my design. I then implemented the design to FPGA and the final output looked good.
But some of the signals in the chipscope didn't seem to work correctly (equal to zero all the time). It shouldn't be like this because the final output depend on these signals. If these signals were equal to zeros, then the output would be zero also.
I wonder if this is due to the signals trimming (or maybe being merged)? I know there are common question about missing signals when someone use core inserter. Is it same to my case also?
Re: Signals in Chipscope.
This may be a trimming scenario, to confirm check the synthesis report for details of trimming of signals.
The best possible way to check the trimming or optimization  is by checking the connectivity through synthesized netlist.
Can you verify this?
Do you have a chance to check post-synthesis simulation to confirm the logic/functional correctness?
Achutha
Visitor yulek
I didn't check the post-synthesis simulation but I did check it in modelsim simulation.
Is there a way to avoid that? I tried several ways suggested in other threads, e.g. (* KEEP = "TRUE" *). But it doesn't work.
Any other suggestions would be greatly appreciated.
Cheers.
I would first suggest to look for the signal connectivity in synthesized netlist and see if is connected as expected.
This will give us the clue of whether to have the KEEP or any attribute to preserve the optimization.
Can you please share the schematic snapshot of the signal?
Achutha
Visitor yulek
The name of the signal is 'hbf_out_vld[15:0]'. But I guess it has been trimmed and merged with 'tar_out_vld' (which are identical).
I tried to add 'tar_out_vld' to chipscope but it still remain at zero.
Please find attachment of the schematic.
Visitor yulek
I tried this:
http://www.xilinx.com/support/answers/44464.html
But it still doesn't seem to work. Any other suggestion?
Hi ,
Can you please try using the keep_hierarchy yes option to preserve the hierarchy?
This will preserve the hierarchy and optimization across boundaries is not done.
If this doesn't help please share the design so that i can check the details and provide you the solution.
Achutha
