Simple question about Plan Ahead
I haven't used Xilinx ISE in about 15 years. Now I'm getting back into it.
Question: How do you create a schematic in Plan Ahead? I can do it in ISE Project Navigator, but then I can't import it into Plan Ahead. And Plan Ahead doesn't seem to have it's own schematic editor. Am I forced to use VHDL or Verilog with Plan Ahead?
Tony
@tonyzlr Yes, you have to use ISE if you would like use schematic editor.
-Pratham
-Pratham
Pratham,
Thanks for your reply. If I use ISE, can I still add a MicroBlaze MCS and SDRAM controller to my project? I am using the
WebPack version. Thanks again.
Tony
