xilinx-zhaosheng
System Generator call Modelsim simulation
Error messages are as follows:
# Model Technology ModelSim SE-64 vcom 10.2c Compiler 2013.07 Jul 19 2013
# ** Error: (vcom-7) Failed to open design unit file "modelsimf.vhd" in read mode.
# No such file or directory. (errno = ENOENT)
# ** Error: C:/modeltech64_10.2c/win64com failed.
# Executing ONERROR command at macro ./modelsim.tcl line 193
florentw
Hi @xilinx-zhaosheng,
This issue is mentioned in AR#39004 (link). You may want to look at it:
Solution:
"This (vcom-7) error message indicates that a problem occurred while trying to open the specified file in read mode.
You need to verify that the path exists and that you have the correct permissions in the directory.
If an environment variable is used in the specification of the filename, ensure that the environment variable is set to a valid value."
Hope that helps,
Florent
Florent
