Tandem PCIe programming issue
I am having an issue with programming the KC705 BPI PROM with the PCIe core example using tandem PCIe. When I program the first file to the KC705 the done bit does not get set.
I am using the BPI prom and using Impact 14.7. The build was done in Vivado 2014.2. I am using  pg054-7series-pcie June 4,2014 as a guide.
I was successful programming the spi PROM but the host system just power cycled.
I have successfully used the BPI PROM for other non-tandem PCIe  designs.
Any help would be much apperceived.
John
Community Manager
Community Manager
Re: Tandem PCIe programming issue
Hi John,
Were you able to program the BPI successfully? Was the fpga not getting configured with the image stored in BPI flash?
If yes, can you please read the status register of the fpga after configuration failure and share it here.
Were you able to program the fpga with the tandem bit file in jtag mode?
Krishna
For some reason I won't let me post with an attachment.
I am using the Digilent JTAG cable to program the prom
The text below is form the impact console during programming and verification
// *** BATCH CMD : setCable -port auto
INFO:iMPACT - Digilent Plugin: Plugin Version: 2.4.4
INFO:iMPACT - Digilent Plugin: found 1 device(s).
INFO:iMPACT - Digilent Plugin: opening device: "JtagSmt1", SN:210203337506
INFO:iMPACT - Digilent Plugin: User Name: JtagSmt1
INFO:iMPACT - Digilent Plugin: Product Name: Digilent JTAG-SMT1
INFO:iMPACT - Digilent Plugin: Serial Number: 210203337506
INFO:iMPACT - Digilent Plugin: Product ID: 30800151
INFO:iMPACT - Digilent Plugin: Firmware Version: 0109
INFO:iMPACT - Digilent Plugin: JTAG Port Number: 0
INFO:iMPACT - Digilent Plugin: JTAG Clock Frequency: 10000000 Hz
Attempting to identify devices in the boundary-scan chain configuration...
INFO:iMPACT - Current time: 6/16/2014 12:05:57 PM
// *** BATCH CMD : Identify -inferir
PROGRESS_START - Starting Operation.
Identifying chain contents...'0': : Manufacturer's ID = Xilinx xc7k325t, Version : 3
INFO:iMPACT:1777 -
Reading D:/Xilinx/14.7/ISE_DS/ISE/kintex7/data/xc7k325t.bsd...
INFO:iMPACT - Using CseAdapterBSDevice
INFO:iMPACT:501 - '1': Added Device xc7k325t successfully.
done.
PROGRESS_END - End Operation.
Elapsed time =      0 sec.
// *** BATCH CMD : identifyMPM
Selected part: 28F00AP30
// *** BATCH CMD : attachflash -position 1 -bpi "28F00AP30"
// *** BATCH CMD : assignfiletoattachedflash -position 1 -file "C:/EntropyDesign/Boston_Scientific/KC705_Tan_14_2/pcie_X4_gen1_Tandem_example/pcie_X4_gen1_Tandem_example.runs/impl_1/KC705_PCIe_Tan1.mcs"
INFO:iMPACT - Current time: 6/16/2014 12:07:29 PM
// *** BATCH CMD : Program -p 1 -dataWidth 16 -rs1 NONE -rs0 NONE -bpionly -e -v -loadfpga
Maximum TCK operating frequency for this device chain: 66000000.
Validating chain...
Boundary-scan chain validated successfully.
1: Device Temperature: Current Reading:   27.73 C, Min. Reading:   25.77 C, Max. Reading:   28.23 C
1: VCCINT Supply: Current Reading:   0.999 V, Min. Reading:   0.996 V, Max. Reading:   0.999 V
1: VCCAUX Supply: Current Reading:   1.805 V, Min. Reading:   1.802 V, Max. Reading:   1.811 V
Core is not loaded.
BPI SLAVE TYPE in Cse_Operate.c is 0
INFO:iMPACT - Downloading D:\Xilinx\14.7\ISE_DS\ISE\data\cse\cseflash\kintex7\xc7k325t_xsdbbpi.cor core file.
INFO:iMPACT - Creating XC7K325T device.
'1': Programming device...
 Match_cycle = NoWait.
Match cycle: NoWait
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
INFO:Cse - Status register values:
INFO:Cse - 0011 1111 0101 1110 0000 1000 0100 0010
INFO:Cse - '1': Completed downloading bit file to device.
INFO:Cse - '1': Programming completed successfully.
Elapsed time =      1 sec.
key: period_frc, value: 0
key: dclk_has_reset, value: 0
key: period_int, value: 10
Found Slave on Bus Index.
Slave Int Type is 83, Slave Index is -1, BPI_SLAVE is 83
Slave Type is 83, Slave Index is 0
Reset Core
Reset Core
Set Data Width
Setting Flash Control Pins ...
Populating BPI common flash interface ...
Common Flash Interface Information Query completed successfully.
INFO:Cse - Common Flash Interface Information from Device:
INFO:Cse - Verification string:          51 52 59
INFO:Cse - Manufacturer ID:             89
INFO:Cse - Vendor ID:                      01
INFO:Cse - Device Code:                   1b
Reset Core
Using x16 mode ...
Set Data Width
'1': Erasing device...
'1': Start address = 0x00000000, End address = 0x000C14EB.
done.
'1': Erasure completed successfully.
Reset Core
Using x16 mode ...
Set Data Width
INFO:Cse - Using Buffered Programming.
'1': Programming Flash.
done.
'1': Flash Programming completed successfully.
Reset Core
Using x16 mode ...
Set Data Width
'1': Reading device contents...
done.
'1': Verification completed.
Elapsed time =     28 sec.
'1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and mode settings.
Hope this helps
John
Community Manager
Community Manager
Hi John,
This log shows that the flash was successfully programmed.
Can you please share the status register log of the fpga as requested in my previous post?
To read the status register, please follow the below steps in impact-
1. Select the device.
2. Go to Debug-> Read Device Status
Also, were you able to configure the fpga with the .bit file in JTAG mode? If you are unable to then there could be an issue with the bit file and in any case, the status register will give us a clue.
Krishna
Hi Krishna,
The following two FPGA status dumps listed below. The first is down loading to BPI and the second is loading the FPGA directly using the .bit file
The BPI Flash did not generate a done status and the direct FPGA load worked.
Status of FPGA down loading to BPI PROM
INFO:iMPACT - Current time: 6/17/2014 7:56:51 AM
// *** BATCH CMD : ReadStatusRegister -p 1
Validating chain...
1: Device Temperature: Current Reading:   26.75 C, Min. Reading:   22.32 C, Max. Reading:   27.24 C
1: VCCINT Supply: Current Reading:   0.996 V, Min. Reading:   0.996 V, Max. Reading:   0.999 V
'1': Reading bootsts register contents...
[0] VALID_0 - ERROR OR END OF STARTUP (EOS) DETECTED                       :         1
[1] FALLBACK_0 - FALLBACK TRIGGERED RECONFIGURATION                        :         0
[2] IPROG_0 - INTERNAL WARMBOOT (IPROG) TRIGGERED RECONFIGURATION          :         0
[3] WTO_ERROR_0 - WATCHDOG TIME OUT ERROR                                  :         0
[4] ID_ERROR_0 - FPGA DEVICE IDCODE ERROR                                  :         0
[5] CRC_ERROR_0 - CYCLIC REDUNDANCY CHECK (CRC) ERROR                      :         0
[6] WRAP_ERROR_0 - BPI FLASH ADDRESS COUNTER WRAP AROUND ERROR             :         1
[7] HMAC_ERROR_0 - HMAC ERROR                                              :         0
[8] VALID_1 - ERROR OR END OF STARTUP (EOS) DETECTED                       :         0
[9] FALLBACK_1 - FALLBACK TRIGGERED RECONFIGURATION                        :         0
[10] IPROG_1 - INTERNAL WARMBOOT (IPROG) TRIGGERED RECONFIGURATION         :         0
[11] WTO_ERROR_1 - WATCHDOG TIME OUT ERROR                                 :         0
[12] ID_ERROR_1 - FPGA DEVICE IDCODE ERROR                                 :         0
[13] CRC_ERROR_1 - CYCLIC REDUNDANCY CHECK (CRC) ERROR                     :         0
[14] WRAP_ERROR_1 - BPI FLASH ADDRESS COUNTER WRAP AROUND ERROR            :         0
[15] HMAC_ERROR_1 - HMAC ERROR                                             :         0
'1': Reading status register contents...
[0] CRC ERROR                                                              :         0
[1] DECRYPTOR ENABLE                                                       :         0
[2] PLL LOCK STATUS                                                        :         1
[3] DCI MATCH STATUS                                                       :         1
[4] END OF STARTUP (EOS) STATUS                                            :         0
[5] GTS_CFG_B STATUS                                                       :         0
[6] GWE STATUS                                                             :         0
[7] GHIGH STATUS                                                           :         0
[8] MODE PIN M[0]                                                          :         0
[9] MODE PIN M[1]                                                          :         1
[10] MODE PIN M[2]                                                         :         0
[11] INIT_B INTERNAL SIGNAL STATUS                                         :         1
[12] INIT_B PIN                                                            :         0
[13] DONE INTERNAL SIGNAL STATUS                                           :         0
[14] DONE PIN                                                              :         0
[15] IDCODE ERROR                                                          :         0
[16] SECURITY ERROR                                                        :         0
[17] SYSTEM MONITOR OVER-TEMP ALARM STATUS                                 :         0
[18] CFGSTARTUPSTATE MACHINE PHASE                                       :         0
[19] CFGSTARTUPSTATE MACHINE PHASE                                       :         0
[20] CFGSTARTUPSTATE MACHINE PHASE                                       :         0
[21] RESERVED                                                              :         0
[22] RESERVED                                                              :         0
[23] RESERVED                                                              :         0
[24] RESERVED                                                              :         0
[25] CFG BUS WIDTH DETECTION                                               :         0
[26] CFG BUS WIDTH DETECTION                                               :         1
[27] HMAC ERROR                                                            :         0
[28] PUDC_B PIN                                                            :         0
[29] BAD PACKET ERROR                                                      :         1
[30] CFGBVS PIN                                                            :         1
[31] RESERVED                                                              :         0
Status of FPGA downloading .bit file directly to FPGA
INFO:iMPACT - Current time: 6/17/2014 8:19:10 AM
Validating chain...
1: Device Temperature: Current Reading:   27.24 C, Min. Reading:   25.27 C, Max. Reading:   27.24 C
1: VCCAUX Supply: Current Reading:   1.808 V, Min. Reading:   1.802 V, Max. Reading:   1.808 V
[6] WRAP_ERROR_0 - BPI FLASH ADDRESS COUNTER WRAP AROUND ERROR             :         0
[0] CRC ERROR                                                              :         0
[4] END OF STARTUP (EOS) STATUS                                            :         1
[5] GTS_CFG_B STATUS                                                       :         1
[6] GWE STATUS                                                             :         1
[7] GHIGH STATUS                                                           :         1
[12] INIT_B PIN                                                            :         1
[13] DONE INTERNAL SIGNAL STATUS                                           :         1
[14] DONE PIN                                                              :         1
[20] CFGSTARTUPSTATE MACHINE PHASE                                       :         1
[21] RESERVED                                                              :         0
[22] RESERVED                                                              :         0
[23] RESERVED                                                              :         0
[24] RESERVED                                                              :         0
[25] CFG BUS WIDTH DETECTION                                               :         1
[26] CFG BUS WIDTH DETECTION                                               :         0
[27] HMAC ERROR                                                            :         0
[28] PUDC_B PIN                                                            :         0
[29] BAD PACKET ERROR                                                      :         0
[30] CFGBVS PIN                                                            :         1
[31] RESERVED                                                              :         0
John
Community Manager
Community Manager
Hi John,
This looks strange. In the first case (FPGA configured from BPI), you were seeing a bad packet error; it means that the bit file is corrupt.
Can you please run the verify operation on the BPI flash again?
If possible, share the bit file with me. I'll try to reproduce it at my end on a KC705 board.
Krishna
Hi Krishna,
Thanks for moving the thread back.
I ran a verification on the prom in KC705 and got the following output on the console:
INFO:iMPACT - Current time: 6/19/2014 9:06:29 AM
// *** BATCH CMD : Verify -p 1 -bpionly
Validating chain...
1: Device Temperature: Current Reading:   28.23 C, Min. Reading:   27.73 C, Max. Reading:   29.21 C
1: VCCINT Supply: Current Reading:   0.996 V, Min. Reading:   0.993 V, Max. Reading:   0.999 V
1: VCCAUX Supply: Current Reading:   1.805 V, Min. Reading:   1.799 V, Max. Reading:   1.808 V
Core is not loaded.
BPI SLAVE TYPE in Cse_Operate.c is 83
Match cycle: NoWait
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
Elapsed time =      2 sec.
Slave Int Type is 83, Slave Index is 0, BPI_SLAVE is 83
Reset Core
Reset Core
Set Data Width
Reset Core
Using x16 mode ...
Set Data Width
done.
Elapsed time =      8 sec.
It looks as if the device gets reprogrammed when a verification is performed.
Also I have attached the bin, bit, and mcs files tha were used for programming.
John
Hi Krishna,
Any update on the KC705 tandem procramming files that I sent.
John
Community Manager
Community Manager
Hi John,
I didn't get a chance to try the files that you shared. I would do it today and update the thread.
Krishna
Hi Krishna,
I neglected to put the emcclk pin in the top level file and constraints.
When I rebuilt it the KC705 the done bit went active. Although now when I power up my PC with the KC705 the system just power cycles.
I don't think this is hardware issue as I have loaded my non tandem design with PCIe and it works.
Basically this design is the example design generated from the Xilinx Vivado tool with PCIe tandem enabled in the IP GUI.
Attached is the bit and mcs files form that build. Could you try it on your KC705 and let me know if you have the same power cycling issues.
John
Newbie wangjixin
How did you solve this problem in the end please?
