The report_utilization file does not record resource usage except IO
I ran a simple verilog project on Vivado Design Suite Evaluation and WebPACK v2020.1 (64-bit) and the report_utilization file only records utilization of IO. The file is transcript bellow. The verilog file is attached.
Copyright 1986-2020 Xilinx, Inc. All Rights Reserved.
| Tool Version : Vivado v.2020.1 (win64) Build 2902540 Wed May 27 19:54:49 MDT 2020
| Date : Mon Jun 22 23:13:15 2020
| Host : Lenovo running 64-bit major release (build 9200)
| Command : report_utilization -file ArnoldMut_utilization_synth.rpt -pb ArnoldMut_utilization_synth.pb
| Design : ArnoldMut
| Device : 7s100fgga676-1Q
| Design State : Synthesized
Utilization Design Information
Table of Contents
1. Slice Logic
1.1 Summary of Registers by Type
2. Memory
3. DSP
4. IO and GT Specific
5. Clocking
6. Specific Feature
7. Primitives
8. Black Boxes
9. Instantiated Netlists
1. Slice Logic
| Site Type | Used | Fixed | Available | Util% |
| Slice LUTs* | 0 | 0 | 64000 | 0.00 |
| LUT as Logic | 0 | 0 | 64000 | 0.00 |
| LUT as Memory | 0 | 0 | 17600 | 0.00 |
| Slice Registers | 0 | 0 | 128000 | 0.00 |
| Register as Flip Flop | 0 | 0 | 128000 | 0.00 |
| Register as Latch | 0 | 0 | 128000 | 0.00 |
| F7 Muxes | 0 | 0 | 32000 | 0.00 |
| F8 Muxes | 0 | 0 | 16000 | 0.00 |
* Warning! The Final LUT count, after physical optimizations and full implementation, is typically lower. Run opt_design after synthesis, if not already completed, for a more realistic count.
| Total | Clock Enable | Synchronous | Asynchronous |
| 0 | _ | - | - |
| 0 | _ | - | Set |
| 0 | _ | - | Reset |
| 0 | _ | Set | - |
| 0 | _ | Reset | - |
| 0 | Yes | - | - |
| 0 | Yes | - | Set |
| 0 | Yes | - | Reset |
| 0 | Yes | Set | - |
| 0 | Yes | Reset | - |
2. Memory
| Block RAM Tile | 0 | 0 | 120 | 0.00 |
| RAMB36/FIFO* | 0 | 0 | 120 | 0.00 |
| RAMB18 | 0 | 0 | 240 | 0.00 |
* Note: Each Block RAM Tile only has one FIFO logic available and therefore can accommodate only one FIFO36E1 or one FIFO18E1. However, if a FIFO18E1 occupies a Block RAM Tile, that tile can still accommodate a RAMB18E1
3. DSP
| DSPs | 0 | 0 | 160 | 0.00 |
| Bonded IOB | 48 | 0 | 400 | 12.00 |
| Bonded IPADs | 0 | 0 | 2 | 0.00 |
| PHY_CONTROL | 0 | 0 | 8 | 0.00 |
| PHASER_REF | 0 | 0 | 8 | 0.00 |
| OUT_FIFO | 0 | 0 | 32 | 0.00 |
| IN_FIFO | 0 | 0 | 32 | 0.00 |
| IDELAYCTRL | 0 | 0 | 8 | 0.00 |
| IBUFDS | 0 | 0 | 384 | 0.00 |
| PHASER_OUT/PHASER_OUT_PHY | 0 | 0 | 32 | 0.00 |
| PHASER_IN/PHASER_IN_PHY | 0 | 0 | 32 | 0.00 |
| IDELAYE2/IDELAYE2_FINEDELAY | 0 | 0 | 400 | 0.00 |
| ILOGIC | 0 | 0 | 400 | 0.00 |
| OLOGIC | 0 | 0 | 400 | 0.00 |
5. Clocking
| BUFGCTRL | 0 | 0 | 32 | 0.00 |
| BUFIO | 0 | 0 | 32 | 0.00 |
| MMCME2_ADV | 0 | 0 | 8 | 0.00 |
| PLLE2_ADV | 0 | 0 | 8 | 0.00 |
| BUFMRCE | 0 | 0 | 16 | 0.00 |
| BUFHCE | 0 | 0 | 96 | 0.00 |
| BUFR | 0 | 0 | 32 | 0.00 |
6. Specific Feature
| BSCANE2 | 0 | 0 | 4 | 0.00 |
| CAPTUREE2 | 0 | 0 | 1 | 0.00 |
| DNA_PORT | 0 | 0 | 1 | 0.00 |
| EFUSE_USR | 0 | 0 | 1 | 0.00 |
| FRAME_ECCE2 | 0 | 0 | 1 | 0.00 |
| ICAPE2 | 0 | 0 | 2 | 0.00 |
| STARTUPE2 | 0 | 0 | 1 | 0.00 |
| XADC | 0 | 0 | 1 | 0.00 |
7. Primitives
| Ref Name | Used | Functional Category |
| OBUFT | 48 | IO |
8. Black Boxes
| Ref Name | Used |
| Ref Name | Used |
Re: The report_utilization file does not record resource usage except IO
Do you have any synthesis warnings about logic being optimized away?  Have you simulated?  Do the outputs of your FPGA change or are they stuck at 0 or 1?
It is shown the message
[Synth 8-4179] divide by zero is illegal ...
every time a modulus operator is found.
bruce_karaffa, the problem is the modular operation. If it is removed, the schematic is normally generated and the circuit simulates properly. Do you understand why this occurs?
