Observer veeru117
UG208 EAPR Document required
I couldn't get any documentation regarding EAPR. There was a document called " Early Access Partial Reconfiguration User Guide(UG 208)" but now it is not available. is there any reference to get it...? anyone please share documentation and reference files of the  documentation...
Thanks and Regards,
Veerendranath
Re: UG208 EAPR Document required
Please get in touch with your Xilinx FAE for this.
Thanks,Vijay
Scholar dwisehart
That manual is from 2006.  Are you sure it is the only one that contains the information you need?  Maybe there is something newer that is available.  How about UG702 for instance?
Daniel
Observer veeru117
@dwisehart
I am working on virtex2p... it won't support new configuration flow.
we should use EAPR flow to implement partial reconfiguration method in virtex 2p... :(
Veerendranath
