08-20-2012 06:51 PM
Dear all,
First please check the error I am getting when I am trying to generate the Clocking wizard IP (for V6) using core generator invoked through ISE
WARNING:coreutil - Failed to generate file: core_v
invoked from within
"deliverEJava $componentName GenerationOptions $TopLevel"
(procedure "components::c12::generate" line 36)
invoked from within
"components::${componentName}::generate"
(procedure "::xilinx::sim::generation::generateCore3rdParty" line 125)
invoked from within
$parameters(componentInstanceID)"
(procedure "main" line 25)
invoked from within
"main $argc $argv"
invoked from within
"return [main $argc $argv]"
(file
"C:\Xilinx\13.2\ISE_DS\ISE\coregen\ip\xilinx\primary\com\xilinx\ip\clk_wiz_v3
ERROR:sim - Unable to evaluate Tcl file:
C:\Xilinx\13.2\ISE_DS\ISE\coregen\ip\xilinx\primary\com\xilinx\ip\clk_wiz_v3_
2\generate\run_legacy_tcl_flow.tcl
ERROR:sim - Failed executing Tcl generator.
_2\generate\run_legacy_tcl_flow.tcl" line 47)ERROR:sim - Failed to generate 'c12'. Failed executing Tcl generator.
Wrote CGP file for project 'c12'.
Core Generator create command failed.
I also tried the divider IP to generator to see if there is problem with the Clocking Wizard IP, but it also showed similar error.
I was getting every thing all right earlier, but I don't know what has happened now that now I am unable to get the IP generated.
Waiting for reply.
Many thanks in advance.
Jaffry
08-21-2012 04:58 AM
Hi Jaffry,
Can you please try the below details and see it resolves
1.Clean up the project and try generate the core
2.Try creating a fresh project and see if you can generate the core
The above two steps is check if this happening due to the project corrupt.
Try re-booting the machine as this may also happen due to java heap or stack issues.
08-21-2012 04:58 AM
Hi Jaffry,
08-21-2012 05:57 PM
Thank you for your reply
Well actually number 1 does not work, but restarting did the thing.
Thank you for your reply. But please what is the reason for this. Since if it appears again, what should I do then.
Bests,
Shan
