bkeitch
Unfixable path issue
I am getting this message:
[Chipscope 16-302] Could not generate core for dbg_hub. Aborting IP Generation operaion. The current Vivado temporary directory path, 'c:/Users/bkeitch/Documents/Xilinx/gtwizard_ultrascale_1_ex/gtwizard_ultrascale_0_ex/gtwizard_ultrascale_0_ex.runs/impl_1/.Xil/Vivado-14820-DESKTOP-8QM2KHC', is 154 characters. Errors on the host OS will occur when trying to insert logic for debug core 'dbg_hub' when temporary directory paths exceed 146 characters. Please move this Vivado project or the Vivado working directory to a shorter path; alternately consider using the OS subst command to map part of the path to a drive letter.
As the path is automatically generated (after my choice of user///documents) this seems a rather poor bit of programmming... how am I supposed to fix it?
sabankocal
Voyager
Voyager
Hi @bkeitch ,
I'm agree with you, it is not normal.
Just to solve your issue, what about locating your design directly into C:/
Saban
<--- If reply is helpful, please feel free to give Kudos, and close if it answers your question --->
thedevvmann
This is how I've dealt withvproblems like these
bkeitch
This won't work. As a user on a work machine I don't have that option, and the issue is the host name, again I can't change that due to company policy.
