tiago0297
Using xil_printf in SDK
I'm sure it's a very beginner problem, but I'm having some trouble in printing a message of my SDK code in the console. I'm using xil_printf to do it and I've configured de STDIO Connection to COM4 and baud rate 11520 in Run Configurations. But when I run my program the console says that COM4 is already being used. The problem is that it's the only port available for me. What should I do?
tiago0297
As I said it's was a beginner problem. I am new to ZedBoard e didn't know that if I connect a cable from the UART to the USB another port will be acessible for the terminal to print messages.
tiago0297
hgraves777
I assume you mean 115200 instead of 11520?  And you don't have anything else open, like a terminal emulator, on COM4.
I need a little more information about your design.  Are you using a development board?  Do you have an RTL UART implemented or are you using a Zynq (PS_UART)?  Windows or Linux?
