VIvado logic analyzer waveform window does not show up in 2014.4
I am trying to use vivado logic analyzer (2014.4). But the waveform window does not show up. I am using ubuntu 64bit.
Jothi
Re: VIvado logic analyzer waveform window does not show up in 2014.4
Yes. It did. When I reduce the freq to 3MHz. Can you explain why?
Hi Jothi,
Are you getting any error message or warning ? If yes please post it here.
Ashish
Hello Jothi,
Is the simulation waveform windows in invoked when running simulation in Vivado 2014.4?
Check this since the same waveform window is being used by Vivado Logic Analyzer.
Also check Vivado.log for any informational messages (Vivado GUI --> File --> Open Log file)
Vinay
Hi Vinay,
1. no error messges shown
2. waveform windows seen in simulation
3. This is the part of log file
open_hw
INFO: [Labtools 27-2285] Connecting to hw_server url TCP:localhost:3121
connect_hw_server -url localhost:3121
current_hw_target [get_hw_targets */xilinx_tcf/Xilinx/000014d2786201]
set_property PARAM.FREQUENCY 6000000 [get_hw_targets */xilinx_tcf/Xilinx/000014d2786201]
open_hw_target
INFO: [Labtoolstcl 44-466] Opening hw_target localhost:3121/xilinx_tcf/Xilinx/000014d2786201
set_property PROGRAM.FILE {/home/adithya/xilinx/Workspace_2014.3/hdmi_3/hdmi_3.runs/impl_1/tutorial_wrapper.bit} [lindex [get_hw_devices] 1]
set_property PROBES.FILE {/home/adithya/xilinx/Workspace_2014.3/hdmi_3/hdmi_3.runs/impl_1/debug_nets.ltx} [lindex [get_hw_devices] 1]
current_hw_device [lindex [get_hw_devices] 1]
refresh_hw_device [lindex [get_hw_devices] 1]
INFO: [Labtools 27-2302] Device xc7z010 (JTAG device index = 1) is programmed with a design that has 1 ILA core(s).
run_hw_ila hw_ila_1
INFO: [Labtools 27-1964] The ILA core 'hw_ila_1' trigger was armed at 2014-Nov-27 11:09:06
run_hw_ila hw_ila_1 -trigger_now
INFO: [Labtools 27-1964] The ILA core 'hw_ila_1' trigger was armed at 2014-Nov-27 11:09:18
INFO: [Labtools 27-1964] The ILA core 'hw_ila_1' trigger was armed at 2014-Nov-27 11:10:12
From the log I see that ILA core is armed. It looks like it's waiting for trigger condition to happen.
Can you try "run trigger immediate"? This should capture and display the data irrespective of trigger conditions.
Deepika.
Deepika.
I tried run immediate also. The waveform window does not show up
This is the log
INFO: [Labtools 27-1964] The ILA core 'hw_ila_1' trigger was armed at 2014-Nov-27 14:15:20
run_hw_ila hw_ila_1
INFO: [Labtools 27-1964] The ILA core 'hw_ila_1' trigger was armed at 2014-Nov-27 14:15:31
INFO: [Labtools 27-1964] The ILA core 'hw_ila_1' trigger was armed at 2014-Nov-27 14:15:38
Hi ,
Can you reduce the JTAG cable frequency and see if it helps?
Deepika.
Deepika.
Hello @jothiadithya
This answer record answers your query: http://www.xilinx.com/support/answers/57934.html
Vinay
