06-24-2020 06:25 AM
Hi Team,
I Tried to generate Hsync and Vsync as per the image frame 640x480. but while simulating the hardware design, Video timing controller not generating the output. what to do to simulate the block design and to see output as per the clock.
I provide the clock and reset signal only, What to do o generate the output.
as per this design only i made the block design. is it possible to generate Hsync and Vsync by using this design.
Please help immediately, what is wrong with the design, i made the required configuration. but not working.
With Regards,
Ratheesh
06-24-2020 06:46 AM - edited 06-24-2020 06:52 AM
Hi @Ratheesh ,
Did you call "Generate Output Products" by right clicking your design on sources tree?
Saban
Hi @Ratheesh ,
Saban
