Vivado 2014.1, Debug
I'm using Vivado 2014.1.  I've been having several issues using an "ila" embedded in the design.  I seem to be having issues with "vcse_server".  I am compiling for the KC705 board.  My error today is the following:
INFO: [Labtools 27-1964] The ILA core 'hw_ila_1' trigger was armed at 2014-May-13 13:43:12
wait_on_hw_ila hw_ila_1
display_hw_ila_data [upload_hw_ila_data hw_ila_1]
INFO: [Labtools 27-1966] The ILA core 'hw_ila_1' triggered at 2014-May-13 13:43:12
ERROR: [Labtools 27-147] vcse_server: Arg. to function CseILA_unrollTraceMemory() failed:traceMemorySize >= (samplewordsizewithmark * sampleCnt * windowCnt)
ERROR: [Labtools 27-147] vcse_server: Could not get Parameter: trace_data.
ERROR: [Labtools 27-1829] vcse_server failed during internal command 'CseXsdb_getParameters'. See previous error messages.
I cycled power on the board.  Disconnected the JAG cable.  Closed out the design.  And finally closed Vivado completely.  I still get the same message.
Any thoughts?
Is the design is build in 2014.1 or any other version?
Can you try setting the trigger within the range?
It's a new design started in 2014.1.
Yes I made sure the trigger point was valid.  I'm creating a new ila and re compiling the design.
Can you check whether there are any timing violations in the design?
This may happen if the ILA did not meet the timing.
After I created a new ila and recompled it works so I can't check the timing.
After I recompiled and added more test points i get this message:
ERROR: [Labtools 27-147] vcse_server: Invalid Register Name: MU1033_WIDTH
ERROR: [Labtools 27-1829] vcse_server failed during internal command 'CseXsdb_getRegisters'. See previous error messages.
1) As Manusha asked you did you checked the timing of ILA?
Is it meeting the requirements?
2) Is your Vivado (design build) version and HW manager version is same?
Yash
All of the tools were installed at the same time so I think everything is 2014.1.  I do not see any timing errors associated with the ila.  When I go to Help/About Vivado I get this:
        Vivado v2014.1 (64-bit)
SW Build 881834 on Fri Apr 4 14:15:54 MDT 2014
IP Build 877625 on Fri Mar 28 16:29:15 MDT 2014
Windows 7, 64 bit
Getting the same error in 2014.2 now.
Oh and I have no timing errors.
Got that error also a lot. It works better since I decreased JTAG frequency to the minimum (750000 Hz).
