Visitor kaylaniu
Vivado 2014.1 ILA transeiver wizard example design
I tried to implement the example design for the Virtex-7 Transeivers Wizard and inserted ILA into my design. I am able to compile and implement, however, when debugging, my outputs are not correct.
For example, the output for probe 1 is supposed to be gt0_error_count_i. Also if there are more transeivers added beyond gt0, they all just give a n_9_gt0_framecheck type of output.
Visitor kaylaniu
Re: Vivado 2014.1 ILA transeiver wizard example design
Fixed it.
You have to 1. make sure to select "none" on Flatten Hiearchy in the Synthesis settings
2. make sure to mark_debug all signals youre probing before the main line of code.
go to pg. 19 here for how to:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2012_2/ug908-vivado-programming-debugging.pdf
That should do it, I think!
Visitor kaylaniu
Fixed it.
