07-22-2014 09:54 AM
Hi All - During implementation of the design with ILA core netlist insertion, I ran into this "unknown error". I am not sure how to go about resolving this issue, since it is unknown. Any ideas or suggestions would be very much appreciated.
Opt Design:
[Chipscope 16-119] Implementing debug core dbg_hub failed.
ERROR: An unknown error has occured while implementing debug cores in this design.
Thank you!
Howard
07-22-2014 11:34 AM
Many thanks Vinay and Vijay both for your ideas and suggestions, I had resolved the issue.
With the initial problem of long path directory under window, I copied the design folder another folder under C to make the directory path shorter. In stead of copying the design folder, I should have File --> Archive Project. By Archive Project, the "unknown error" has gone away.
Howard
07-22-2014 10:00 AM
Hi Howard,
If you are using windows, reduce the directory path length and give a try.
Vinay
07-22-2014 10:08 AM
07-22-2014 10:36 AM
Hi Vinay and Vijay:
Thank you for your feedback.
I am using window 8, and initially I had the problem of a directory path length, as Vinay has suggested. I then copy the project to a different folder right under C directory, to make the path shorter. I then ran into this "unknown error".
If nothing else, I will try Vijay's suggestion of creating a new project.
Howard
07-22-2014 11:28 AM
The issue may occur if the Debug Hub in cache is out-of-sync and needs to be cleared with the following command.
update_ip_catalog clear_ip_cache
Can you try running the above command and check whether it helps?
07-22-2014 11:34 AM
Howard
07-22-2014 05:58 PM
07-23-2014 03:48 PM
Is this a valid command? It fails to run at my end.
Also regarding the failure above with "unknown error", using all the suggested solution above did not help. The problem got resolved when I added the header file "`include "cs_ver_inc.v"" to the top level design.
