Vivado 2014.2 crashes when opening target in hardware manager
This happened a few times now. Here is the latest error message:
# An unexpected error has occurred (11)
Stack:
/Xilinx/Vivado/2014.2/tps/lnx64/jre/lib/amd64/server/libjvm.so(+0x8127a9) [0x7fbe6e0e47a9]
/Xilinx/Vivado/2014.2/tps/lnx64/jre/lib/amd64/server/libjvm.so(JVM_handle_linux_signal+0xb6) [0x7fbe6e0ea216]
/lib64/libc.so.6(+0x385b0) [0x7fbe9516e5b0]
/Xilinx/Vivado/2014.2/lib/lnx64.o/librdi_xicom_hw.so(XicomHWXicomGetDevicePropertiesCmd::getCfgmemSupported()+0) [0x7fbe73170680]
/Xilinx/Vivado/2014.2/lib/lnx64.o/librdi_labtools.so(Java_ui_data_labtools_lthwdatai_HWDevice_1isXicomCfgMemSupported+0x17) [0x7fbe772163e7]
[0x7fbe67d5f2d1]
Is this issue intermittent?
Provide the steps that helps to reproduce the issue.
Vinay
Hi, yes it only happens occasionally but I haven't made out any pattern. Maybe important: I use a remote server. Version 2014.2 of hw_server is installed.
It just crashed again when I tried to modify the JTAG frequency giving out this slightly different error message:
Stack:
/Xilinx/Vivado/2014.2/tps/lnx64/jre/lib/amd64/server/libjvm.so(+0x8127a9) [0x7f2b442f57a9]
/Xilinx/Vivado/2014.2/tps/lnx64/jre/lib/amd64/server/libjvm.so(JVM_handle_linux_signal+0xb6) [0x7f2b442fb216]
/lib64/libc.so.6(+0x385b0) [0x7f2b6b37f5b0]
/Xilinx/Vivado/2014.2/lib/lnx64.o/librdi_xicom_hw.so(XHWDevice::getCfgmemSupported()+0) [0x7f2b49344ea0]
/Xilinx/Vivado/2014.2/lib/lnx64.o/librdi_labtools.so(Java_ui_data_labtools_lthwdatai_HWDevice_1isXicomCfgMemSupported+0x17) [0x7f2b4d4273e7]
[0x7f2b3d297e4d]
Earlier crashes happened when I tried to open a recent target directly or when I tried to connect to the remote server.
What is your server operating system and the client operating system?
End the hw_server processes on your client machine (you sometimes have to end it from the task manager) and try creating a new one. See if it works now.
Anirudh
Hi, I restarted hw_server but the problem stayed the same.
Operating systems:
Server: Gentoo
Client: Scientific Linux CERN SLC release 5.10 (Boron)
If possible diable firewall and check if it works.
Anirudh
