Vivado 2017.1 Crashes when opening Synthesized Design
As the subject says, each time I try to open a Synthesized Design (to add Debugging), Vivado Crashes.
I'm running on CentOs 7. Create a Block Design from Scratch, add one of my IPs, etc ...
This particular design is targeted to a Xilinx AC701 board, but I saw the same when targeting VC707 boards.
This is the Crash window output:
# Vivado v2017.1 (64-bit)
# SW Build 1846317 on Fri Apr 14 18:54:47 MDT 2017
# IP Build 1846188 on Fri Apr 14 20:52:08 MDT 2017
# Current time: 5/31/17 2:13:09 PM ICT
# Process ID: 7432
# OS: Linux
# This report is an indication that an internal application error occurred.
# This information is useful for debugging. Please open a case with Xilinx
# Technical Support with this file and a testcase attached.
java.lang.UnsupportedOperationException: This is supposed to be overridden by subclasses.
at com.google.protobuf.GeneratedMessage.getUnknownFields(GeneratedMessage.java:262)
at ui.data.device.d.l.getSerializedSize(SourceFile:8409)
at com.google.protobuf.AbstractMessageLite.toByteArray(AbstractMessageLite.java:67)
at ui.data.device.H.axB(SourceFile:531)
at ui.data.device.H.axy(SourceFile:454)
at ui.data.device.H.axl(SourceFile:276)
at ui.data.device.E.j(SourceFile:122)
at ui.data.device.E.<init>(SourceFile:63)
at ui.data.ah.lN(SourceFile:1347)
at ui.data.ah.cP(SourceFile:217)
at ui.data.ah.<init>(SourceFile:146)
at ui.data.aW.<init>(SourceFile:38)
at ui.project.a.edJ(SourceFile:252)
at ui.project.a.init(SourceFile:236)
at ui.project.r.a(SourceFile:1080)
at ui.frmwork.a.k.d(SourceFile:41)
at ui.frmwork.HTclEventBroker.i(SourceFile:259)
at ui.frmwork.HTclEventBroker.fireTclEvent(SourceFile:330)
at ui.frmwork.designcmds.HTCDesignCommands_openRun(Native Method)
at ui.a.t.a(SourceFile:216)
at ui.a.t.F(SourceFile:205)
at ui.views.O.n.K(SourceFile:210)
at ui.b.c.bB.construct(SourceFile:763)
at ui.frmwork.D.run(SourceFile:201)
at java.lang.Thread.run(Thread.java:745)
Many Thanks,
rudi
Re: Vivado 2017.1 Crashes when opening Synthesized Design
@asics.ws
The information in below Answer Record should help in resolving the issue:
https://www.xilinx.com/support/answers/69088.html
--Syed
@asics.ws
--Syed
Thank you very much ! This solved the issue !
Best Regards,
rudi
