[Vivado 2018.3] Xicom 50-38: Unknown deviceType:1
Hello everyone,
I'm using Vivado 2018.3. In my block design, I add system ILA with 1 slot AXIS to debug my signal.
When running Hardware Manager and run all to capture signal, following error was appeared:
[Xicom 50-38] xicom: Unknown deviceType: 1
[Xicom 50-38] xicom: Could not set Parameter: capture_ctrl_config
Anyone know this error please show me how to fix it?
Thank you so much,
Re: [Vivado 2018.3] Xicom 50-38: Unknown deviceType:1
Hi @yurivn,
The ILA has a parameter called DATA DEPTH. It appears that yours is not being set correctly (or might be getting set above the limit for some reason).
Could you please run the following command to see what it reports back:
get_property CONTROL.DATA_DEPTH [get_hw_ilas]
It normally comes back with a value power of 2 (1024, 2048, etc.).
You can try to also force set it to the default value of 1024 and try to run the ILA trigger again:
set_property CONTROL.DATA_DEPTH 1024 [get_hw_ilas]
Andre Guerrero
Product Applications Engineer
I also got the same message and
1024
doesn't fix the problem.
What else could it be?
