Observer mfrancis
Vivado 2019.1:- ILA Waveform Radix
in my ILA waveform i have the signals radix set as signed decimal. When i do a export ILA data to CSV file it only saves it as HEX.
How can i save to CSV in decimal format?
are there any TCL scripts to do this?
Observer mfrancis
Re: Vivado 2019.1:- ILA Waveform Radix
I came across this question in the forum from 2015 and one of the repies was this was being added i.e the ability to save in the same format you have the ILA set up as. any reason why this has not been done?
I think you have a misunderstanding. Storing format and representation are different. For example, a float is stored with an awkard format for humans, and it is represented as we like it.
If it helps, you can open a CSV with excel, the there is a function HEX2DEC or something like that.
Observer mfrancis
thanks for the reply. but no misunderstaning. .
Its really the format i have selected to show my data in a ILA waveform is saved as that format in a file.
Now i have to save the csv file, and the least i have to do is write a python script to read and convert. I cant see why Vivado can not include a script in its tools that does it for me.
Ok, I got it. My misunderstanding actually. By 'saved' you meant 'saved to the CSV' I understood 'saved in memory'
Yeah, Python will surely save the World
Scholar drjohnsmith
Its TCL that saved the universe !!! :->
seriously , dont hod out hope for Xilinx to add features to anything apart from Vitis for the next few years.
In TCL we trust
Hi @mfrancis,
Could you please check that you are correctly setting the waveforms to decimal? And you are exporting it to CSV, right?
I have personally worked on it before and had the developers fix it (that was a couple years ago, I think).
I just opened Vivado 2019.1 with an ILA design and performed a test. I have a counter that just counts up to 127 and then restarts from 0.
I set the Radix for that probe to HEX, Binary, and Unsigned Decimal, and exported the data to CSV for each case. The data was saved in the correct format in all cases (see images below).
ILA_export_HEX.pngHEX
ILA_export_BIN.pngBinary
ILA_export_Decimal.pngUnsigned Decimal
Andre Guerrero
Product Applications Engineer
