Vivado 2020.1 crashes on Ubuntu 20.04
Hi.
Recently we've switched our development servers from Centos to Ubuntu 18.04,
Since we did that, Vivado crashes. we specifically selected Ubuntu 18.04 because it stated that it supposed to be supported.
This is the crash error we get:
CRITICAL WARNING: [IP_Flow 19-1747] Failed to deliver file '/data/common/xilinx/Vivado/2020.1/data/ip/xilinx/versal_cips_v2_0/xit/init.xit': Caught unexpected error when evaluating file '/data/common/xilinx/Vivado/2020.1/data/ip/xilinx/versal_cips_v2_0/xit/init.xit'
ERROR: [IP_Flow 19-167] Failed to deliver one or more file(s).
I attached the log files that were produced.
Tags (2)
Hi @rfried ,
stupid question: is the missing file available on your file system?
If not, your installation might be corrupt. I can confirm, that this file should be at the position vivado is looking for.
Sebastian
Hi.
The file exists and has the right permissions.
I am having exactly the same issue on Ubuntu 20.04, happens mostly when building for Versal
