tn45eng
Vivado IP GUI customization
Hello!
I'm having 10 different ports in an entity that I"m packing using Vivado. I'll have to display/ generate ports based on the customization parameters selected.
I gave it a shot and tried searching the forum but I can't find a better way to do it.
Any help is appreciated.
pratham
@tn45eng #50
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug1118-vivado-creating-packaging-custom-ip.pdf
-Pratham
pratham
@tn45eng #50
-Pratham
