Vivado Logic Analyzer trigger condition operator
I am only getting AND/NAND option in the Logic Analyzer GUI for a basic trigger setup. Running
set_property CONTROL.TRIGGER_CONDITION OR [get_hw_ilas hw_ila_1]
results in
ERROR: [Labtools 27-1388] Since this hw_ila [hw_ila_1] has multiple hw_probes, sharing the same ILA probe port, only trigger condition values AND/NAND are allowed.
The debug core is created entirely by the Set up debug wizard and looking in the constraints there are multiple debug ports created, one for each signal or bus. Why the error then?
Re: Vivado Logic Analyzer trigger condition operator
This is know issue with Vivado 2013.1 and its fixed in Vivado latest release.
Which version you are targeting?
Vivado 2014.4 is available now for customer try using latest version.
Also to workaround this issue in older version, don't add one (concatenated) net to one probe more than once.
Yash
It seems to be still present in 2014.3.1
FYI.. 2014.4 is the latest version.
Did you tried the workaround not to probe net more than once?
If you still face this issue, share your test case and steps to reproduce this issue.
Yash
The bug is still present in 2014.4. I tried the bitstream and debug probes file generated in 2014.3 in 2014.4.
I will have to look at the debug nets, I might be probing the same net from different hierarchy levels.
Just to narrow down the issue. Please probe few nets and check if problem persist or not?
Yash
