Vivado Release Schedule
Our team would like to plan when to move to the next versions of Vivado.
Will there be 2 releases in 2020, about May and Nov?
Re: Vivado Release Schedule
@david.bleakley
Please get in touch with your regional Xilinx FAE to know the details.
https://www.xilinx.com/about/contact.html
--Syed
@david.bleakley
--Syed
