Vivado quit overnight
I tend to keep Vivado (v2018.2)running overnight but whenever I come into the morning vivado always quit and I have to open it up again. I remember this didn't happen with earlier version.
Is there a way to keep Vivado from quitting when I leave the office overnight?
Its strange thats for certain,
as its only the last month or so, it sort of narrows down a bit, less likely to be a Vivado thing,
Im going to have to pass listen out for what the answer is Im afraid
good luck
Id suggest its most likely to be your company IT imposing a restriction or windows over night update ,
Strange but other applications doesn't quit. Only Vivado
I'll give you that then as strange,
is this the licenced version or the free one ?
wonder if its your licence server ?
Its strange, we run vivado 24/7 in various companies I work with, ,
This is a license version running on a remote linux pc
It always stays on overnight.
I noticed It started to quit overnight  within the last month or so.
Could it be if I have the ILA on
good luck
I believe it is the ila that kills vivado overnight.
